Enables the transmission of LLDP SNMP trap notifications related to LLDP MED extension TLVs.
| all | Specifies all ports on the switch. |
| port_list | Specifies one or more ports or slots and ports. |
Disabled.
If you do not specify any ports, the system sends LLDP-MED traps for all ports.
The following command enables LLDP-MED SNMP traps for all ports:
enable snmp traps lldp-med ports all
This command was first available in ExtremeXOS 11.5.
